Car wont start! what are the options?
Old Feb 28, 2010 | 03:19 PM
Jesusloves's Avatar
Default Car wont start! what are the options?
I just put a regular single cam dx in my civic, but it won't start up, it was running fine for a bit, but all of a sudden it wont start back up. it'll crank, but it sounds like its not getting fuel. its kinda got like a burbbling popin sound, like poof, poof,poof, as ur cranking it. lol. sorry. what could it be? fuel pump? injectors? spark plugs?
Old Mar 2, 2010 | 07:30 PM
mrchad's Avatar
I would squirt some either down in and see if she pops on that. If so you then know its a fuel problem.
Old Mar 3, 2010 | 01:23 PM
Jesusloves's Avatar
squirt some down in where?
Old Mar 3, 2010 | 07:46 PM
mrchad's Avatar
down the air intake,i.e. follow the large tube back from the air filter,then dissconect it at the metal plentum where the throttle linkage is @... then open the throttle butterfly a bit then squirt some in.
Old Apr 5, 2010 | 10:21 AM
MAJORAHOLE's Avatar
jesus christ, really?
there are 3 parts need to run an engine. 1 fuel, 2 air, 3 spark
check fuses and what not.
does your fuel pump prime when you turn the key to the on position??
Old May 6, 2010 | 05:32 PM
whitecivichatch88's Avatar
i would check you timing belt, kinda what it sounds like just take oil fill cap off and have some one crank, and watch for the rocker arms movin if you still have the t-belt cover that is, t-belts snap all the time its one problem i see quite a bit of and make good money off of fixing the bent valves
Old Sep 10, 2010 | 10:10 PM
neubie's Avatar
did you check for engine codes?
Old Apr 15, 2011 | 02:45 AM
theEFbuild's Avatar
do you have good motor grounds similar problem happened with my old single over head turned out the tranny ground came loose good motor ground is essential
Old Jan 17, 2012 | 07:25 PM
Zeusfire69's Avatar
Unhappy
I agree with white civic hatch 88....it sounds to me like your timing belt was tensioned correctly and it skipped after running for a while. Hope it didn't hurt any vavles!!
Old Feb 5, 2012 | 08:29 PM
Zeusfire69's Avatar
Duh!!sorry, I meant WAS NOT tensioned correctly...
