Welp, I sold the white hatch shell and suspension, and this is all of what I have left. Getting out of Hondas for good, everything needs to go. I am firm on some stuff but everything is OBO. I prefer the items to be picked up, but can meet up to a reasonable distance if my schedule works out. Will ship, you pay shipping. All parts are located in Dahlonega, GA. Some parts are still dirty as I haven't had the chance to clean them.
-B18A1 Engine - $350 - #1370772, 170k bottom end. 15k on new top end - Replaced valve stem seals, valves lapped, timing belt, water pump, head gasket, cam seals, etc.
-LS Cable Transmission w/ LSD - $500 - Rebuilt, new 3rd & 4th gearset, new shift fork, OEM diff. bearings OBX LSD unit- rebuilt w/ upgraded bolts & washers.
-DSM 450 Injectors - $80 -
Obd1 Remanufactured Distributor - $60 - Advance Auto Parts lifetime warranty.
Chipped P28 Ecu - $100 - Purchased from Scotty @ Digitalboxtuning - OBD0 to OBD1 conversion harness too
Hasport B Series EF Mounts - $220
EF B Series Shift Linkage - $50 - Custom cut/welded
InlinePro Cast Turbo Manifold - $250 - B series, T3
Deltagate 38mm Wastegate - $75
JohhnyRaceCar FMIC- $200 - Good condition, just had FatCatFabrication weld on some new mounting tabs
AirResearch M10 T3 - $25 - Needs rebuilt, has shaft play
D16 Mpfi Intake Manifold - $30 - Comes with throttle body, tps
Si Mpfi Injectors - $30
Si obd0 Distributor - $40
Resister box - $10 - Have 2 of these
PM6 Si Ecu - $40
Camber Kit Front- $40 - Unknown brand, comes with DA A arms
EF Rear Strut Bar - $10 -
Turbo Timer -$20 - Swoosh
D15B Engine $50 - #3641858 Unknown mileage, turns over. PO replaced said it ran, but smoked. Rings??
HF exhaust manifold- $20 -
B18A Rebuilt Bottom End - $175 - Oem piston rings, ACL rod & main bearings w/ new thrust washers. All bearings platicgauged, and cyls. honed. New water pump, Comes with Feltpro topend gasket kit
B18A Head $25- Disassembled, everything's there though. Its under the other mess, lol
Interested in the Jumper Harness on the ECU and the Injectors, would you separate the harness from the ecu? If so, give me a price shipped to WA, 98023.
Sorry harness is no longer available. Which injectors?? The DSMs??
