Go Back   HomemadeTurbo - DIY Turbo Forum > Homemadeturbo > Forced Induction
Old 05-01-2009, 05:42 AM   #1
Bulletman
Make: Honda
Year: 1989
Default Check valve
this pic is off of Turbo Project CRX DX under "charge piping"
i need to make one of these check valve thing.. to stop check engine while under boost... can anyone tell me whats the basis behind it and the best way its done? i tried searching... all i get is freekin catch can diy's..
Bulletman is offline   Reply With Quote
Old 05-01-2009, 09:09 AM   #2
SilverSRT8Boostedz6
You ban buy check valves from any aquarium store
SilverSRT8Boostedz6 is offline   Reply With Quote
Old 05-01-2009, 09:26 AM   #3
SilverSRT8Boostedz6
Double post
Old 05-01-2009, 01:27 PM   #4
Bulletman
Make: Honda
Year: 1989
Quote:
oh.. ok i get it, to not let boost creep up by the sensors, omw to get one right now.
Old 05-01-2009, 02:19 PM   #5
iceracerdude
iceracerdude's Avatar
I'm using a thing called a "krankvent" it's supposed to hold back like about 75 psi if I remember correctly, so I'm still using the pcv system off boost. They come in a couple of different sizes. It costs a little more money than an aquarium valve, but then again last time I checked my engine is worth more than an aquarium. I've got it setup right after the pcv valve in the picture. On the valve cover on the other side of the charge pipe, I'm just taking in a little atmosphere air. I don't even need a catch can and I don't blow any oil out of that tube either. Yeah, I was shocked at that one too, but that krankvent is fast and seals perfect.
iceracerdude is offline   Reply With Quote
Old 05-02-2009, 09:52 PM   #6
Bulletman
Make: Honda
Year: 1989
hmm ok here is what i know, the whole point of the check valve is to "bleed" boosted air thats creeping up my vacuum lines to the sensors.
So to hook it up i would tee off my vacuum line before my map sensor, one end would be map other would be source of vacuum and middle the check valve to vent into atmosphere to function properly?
Old 05-02-2009, 09:59 PM   #7
arok22
Make: Honda
Year: 1994
Quote:
Dude! what kinda engine/car you have? That looks freakin stock!
arok22 is offline   Reply With Quote
- by chenzob
- by CreeK
