alright i got a question, i dont feel like getting a catch can and all that ---- so would it be alright if i just ran the crank case vent to turbo inlet and stuck a oil separator.
http://focus.c-f-m.com/index.asp?Pag...OD&ProdID=1127
With the price of that kit I wouldn't see why you wouldnt just do it right and make your own catch can. Pretty much there is no way to get around modifing your PCV setup without using a catchcan. Either you run a vented catch can or you run a sealed catchcan while utilzing the beroulli effect catch can. I did my entire setup with the sealed catch can for under $100.
the aircompresor filter is only $10
If your PCV valve fails than you run the risk of pressurizing the crankcase. Than you will have opposing pressure on the top and bottom of the piston...not a good thing. Don't risk your engine for under $100 to do it 100% correct. you can do it for like $30 if you really want to. No point to risk what you got for such cheap $$$.
I need these pictures. Like a crackhead needs crack.
http://absolutecoolness.com/filepile/crackhead.jpg
to be PC.
http://www.stickfight.net/images/ava...-crackhead.jpg
to be PC.
