Homemade Boost control at it's finest...
Old Nov 21, 2007 | 06:18 PM
  #71
xxguyxx's Avatar
Default Re: Homemade Boost control at it's finest...
This is AWESOME, but any boost spiking with this set up? i built a similar MBS a while back, it was a dual stage. it spike when you mashed the gas in a high gear. example. 35 mph 3 gear or on interestate trying to pass a car in 5th. i tried misc fitting sizes, bleed hole sizes, pretty much everything. could never get rid of the 2-3 psi spike.
Old Nov 23, 2007 | 01:31 AM
  #73
Originally Posted by Dmc1
if it's only two to three psi then it's not spike. Just a small gift
+1
Old Nov 23, 2007 | 10:16 PM
  #74
turbo4life's Avatar
Originally Posted by Ogubudiah
so how do you switch the maps to accomodate this, while driving?
this is boost levels as long as its tuned for up to the max boost u run but ya fine tunning will be need if the low boost area was not tuned like most tuner just tune at WOT full boost.. but your probably confusing this with switching maps for different fuel octane.... witch all i knwo of is on turbo vw..
Old Nov 27, 2007 | 02:15 AM
  #76
turbo4life's Avatar
Originally Posted by leed
That CRX is ------- sweet. Maj. Dick, hahahaha
I used a vacuum solenoid activated via a levered micro switch on the throttle body before. Floored was low boost, mashed into the carpet was high boost. In reality, it didnt work because Id get too excited and mash it into the carpet no matter what :1
If you're local to a pull-a-part style yard, grab the giant firewall mounted black box off a mid 80's carbed honda. The ones with ten miles of vacuum lines. There will be about 8 of those valves in there + all kinds of useful vacuum fittings and such.
WORD to this brother
Old Nov 27, 2007 | 02:25 AM
  #77
turbo4life's Avatar
Originally Posted by Joseph Davis
Prepare for law enforcement's ability to dial your throttle down to a valet mode, where it can only open 10% or so... just enough for you to limp to the side of the road and wait for your speeding ticket.
i bet thats the governmetns evil plan to take control of all the people so u cant run from the government..why else would they add this ---- it dosent make driving esier and more ---- to go wrong my dads cummings powered dodge ram 2002 has a problem wiht the drive by wire bull ---- it drives then it just dies i have to switch off the ignition key wile driving to get it to work again..(not to mention how dangerious that is in case u switch it off completely and lock the steering colom.. )
oh ya and look google search smart chip mondex
Old Dec 25, 2007 | 11:51 AM
  #78
con's Avatar
con
Originally Posted by Speed Phreak
for whatever reason I have never klicked this link before, I ------- love that paint job!! Gangster as ----, you my friend are a true warrior
Old Jan 14, 2008 | 12:20 AM
  #79
D16y7DX's Avatar
wow I thought I knew what I was talking about when it came to turbo kits.....I was soooo wrong.. I need to start taking notes. no joke. lol noob status all over again.
Old Jan 16, 2008 | 02:14 PM
  #80
SpoolinZc's Avatar
I have got a T valve with a **** on it, when you turn the **** down you can restrict air flow, i was wondering if that will work as a boost controller
