Old Mar 20, 2006 | 12:28 AM
  #61
92 4doorsleeper's Avatar
Originally Posted by rawr
http://www.fastbygast.com/Catagories...ion/Vacuum.asp
Ever wonder what that buzzing noise was coming from inside a Pro Stocker before they fired up? It's a Pro Stock secret... at least until we told everybody! That noise is coming from an electric vacuum pump. It's purpose is to evacuate the engine cases of unwanted pressures and make the piston rings seal better. The result is my favorite thing... HORSEPOWER! Well... almost my favorite thing.
Features:
Oil-less operation
Permanently lubricated bearings
Built-in cooling fan for constant use
Convenient mounting tabs
Closed housing and motor
Stainless valves and aluminum valve plate
Die cast aluminum head and diaphragm hold down plate
Balanced for smooth, low vibration operation
Long-life diaphragmHelps prevents oil leaks
Cheap money... easy installation... increased horsepower...
Wouldnt one of those things for a fish tank do the same?
Old Mar 22, 2006 | 08:49 AM
  #62
ichbinsobose's Avatar
Alright, after all this it seems all you have to do is connect both pcv/vc vent sources and then connect them through a pcv to a constant vacuum source. Yes?
Old Mar 28, 2006 | 10:01 PM
  #63
michigan_soler's Avatar
i think the problem is that you need it to be ok to get some water in it, unlike a fish tank one... and a fish tank thing goes the wrong way... it blows air and you need to suck air...
it also may not be enough vacuum...
did anyone ever figure out how much vacuum we need?
Old Mar 29, 2006 | 09:20 PM
  #64
15hg is what I heard.
Old Mar 30, 2006 | 11:54 PM
  #65
benscivic's Avatar
so in other words use this setup but use another pvc between the intake of the turbo and the catch can right in the oppiste way
Old Mar 31, 2006 | 04:36 AM
  #66
Andrea's Avatar
pics for the first post not working
Old Mar 31, 2006 | 07:10 AM
  #67
B16CRXT's Avatar
well there should be no need for a pcv valve btwn the can and the intake. Boost doesnt come out of the intake. The pcv valves are to keep boost out of the can/block.
Old Apr 19, 2006 | 09:00 AM
  #68
civic_16s's Avatar
Ok. Here is my current (and very simple) setup. I don't have pre intake pipe (filter directly on compressor inlet), so I do that.
There isn't PCV valve anymore.
Please comment ...
Old Apr 19, 2006 | 09:16 AM
  #70
civic_16s's Avatar
Thanks
So it would be a better idea to use a breather filter on the valve cover, and don't use the second port of the catch can.
(just to be sure, English isn't my mother language).
