Filling Block... How To.... UPDATED
Old Apr 7, 2005 | 01:14 AM
  #61
neather1's Avatar
Default Re: Filling Block..... How To
yea daily driver my bad. i would like to do somethin like this but i would be driving my car every day. recomendations?
Old Apr 8, 2005 | 09:38 AM
  #62
bumblezc's Avatar
Well crx304 is "testing" it on his car for daily driving aplications.
I think alot of us are waiting to see how it turns out over the summer. I know I am!
But either way, I would probably want a spare block arund just in case.
Old Apr 11, 2005 | 08:42 PM
  #63
tranceminister's Avatar
Sounds promising thus far
Old Apr 15, 2005 | 10:25 PM
  #64
crx304's Avatar
2000 + miles so far and real nice 70* days... beat the ---- outta it whenever i can
Old Apr 18, 2005 | 02:04 AM
  #65
95civic's Avatar
sounds good how much boost do you run daily like 15-17psi?
Old Apr 18, 2005 | 02:38 AM
  #66
Originally Posted by ****
beau runs a filled b16, 33psi and i think it was like 460whp, 25* timing.
blundar was telling me about a Cincy shop that had a turbo B16, stock block, DSM 450cc, AFC hack, racegas, leaning into the 14:1 AFRs, 445 whp. So?
Filling the block SEEMS like a good idea in my mind, but there isn't a big enouh body of evidence to support that yet. Stock sleeves are weak, period, is all I can state when it comes to Honduhs... everything else is opinion, conjecture, etc. I plan on filling a block at some point, but in the meantime lets not bandwagon hop.
Old Apr 21, 2005 | 12:10 AM
  #67
BLACKSI's Avatar
my setup
stock bore b16 "speacil top secret mod to allow for a deper fill"
moroso block filler
used factory head gasket "top secret gasket spray"
used factory head "bolts"
tubonetics 60-1 (33psi on the dyno 28 at the track)
running a T stat
as far as cooling goes if i have the thing fully warmed in the pits ad have to wait in the staging lanes for say 15min i can barley get it warmed back up before a run
sitting on the dyno for hours it only over heated once when the guy in the car forgot to switch the fan on
from my experience i would totaly recomend it for any low budget racercar from reading crx304's experience why not try it out.
Beau
Old Apr 21, 2005 | 11:32 AM
  #68
bumblezc's Avatar
Ah, you can't give in on at least the TOP SECRET mod to fill the block lower?
Old Apr 21, 2005 | 11:38 AM
  #69
whiterice's Avatar
if you needed to get your block milled, couldnt you fill the block upside down up to the water line.
then any excess on the deck surface would be milled off. seems like it would get maximum amount filled.
Old Apr 21, 2005 | 06:28 PM
  #70
juli0_bustamante's Avatar
please explain how to fill it upside down......
