The ITB info thread.
Old Dec 21, 2006 | 09:49 PM
  #51
Default Re: The ITB info thread.
Originally Posted by slo_crx1
Ok JD...I'll ask you since you have alot more knowledge on this whole itb setup situation. I found a place near me that's pretty much a boneyard for street bikes (for some reason they're a huge thing in my area ).
Yeah, how else do you think the guys who steal streetbikes get titles for them? They buy wrecked frames with titles from said boneyard.
Would it even be beneficial for me to look into an itb setup for my ls/vtec? I'm not talking basic bolt-on crap either like the guy above, expecting to see around 200-ish+ whp. So far I sit at 12.75:1 c/r, as soon as I can get my subaru back together for the winter I'm ripping the b16a head out of my hatch and taking it to one of my friend's shop so we can work on it. We're going to do a port-match and polish, Omni flat faced valves, Omni springs and probably their locking retainers. I plan on flow-testing the head during the whole process and see how much additional cfm I can get out of it. And seeing as how my friend grinds race-cams, he's going to do me a huge favor and grind me something custom based off of the usual itr cam that can match to both my springs and motor as much as possible. So what I'd like to know from you is if there is any hmt style itb's that would be large enough to support this, or would it just be a miserable waste of time and I should just stick with either an aebs or blox type run of the mill intake manifold?
Unless the new 1.6 'busas are running something unusually large I'd skip over motorcycle ITBs entirely. Your power can be made off a single plane IM with no problem, and keep a stock idle and driveability. I'm a big advocate of simplicity. *shrug*
Old Dec 23, 2006 | 03:29 AM
  #52
The simple fact that most people dont want to hear
ITB's are more a pain than pleasure
For the typical joe a nice manifold like an aebs,blox,itr for the b series head with proper porting and a good size throttlebody 65-70mm plate area is where power will be made on 190+whp b series builds. Also like JD has said tuning a plenum all motor set up in my opinion is very stright forward and in the skills of anyone with basic ecu skills can get the job done on the street in 2 hours, atleast thats my experince
Key too all motor builds is cfm. I have seen what it take to make alot of power on all motor builds being close with one of the first guys to start the all motor than back when I was still riding a skateboard
He achieved 190 whp b16a over 6 years ago on ctr cams,pm6 ecu w/some generic chip rpm switch,ported gsr head,gsr manifold,70 mm rpm tb the first generation when Jon at RPM and Dave at dhracing first made the design that was only a straight through inlet no taper
The key with that build was simple the head flowed and made power. Im comfortable to say that head with proper tuning a header built for a b16a, had an edelbrock and tuned on crome would of been a 200 whp build all on a old school b16a1 shortblock
Conclusion want to make power all motor have a friend who knows how to get 300 cfm out of a head or pay 1000+
Old Dec 23, 2006 | 10:26 PM
  #53
A20A3T's Avatar
Originally Posted by Joseph Davis
For naturally asphxiated no power cars, more flow is usually more power. Do you really think motorcycle ITBs the size of drinking straws aren't a restriction?
would ITBs benefit an 89 accord which makes like 90whp? im planning on doing a turbo build when spring comes, but i wanna have fun with some ITBs im getting for cheap
Old Dec 24, 2006 | 10:56 AM
  #54
Slo_crx1's Avatar
Nope. If it's the carb'd version, one of your weakest links is the lack of mpfi. If you're lucky enough to have one of said lx-i's, then the head is more or less the weakest link. I used to rev mine up to 7000 and all I can say is monster valve float after the 5500 mark, especially if the motor's got some miles on it. New valvetrain and a cam helps them quite a bit, along with some port work to help those stock 12 valves breathe a little better. Best of all, cams for those motors are dirt cheap. Replacing the stock restrictive exhaust also helps alot as well, especially after said head work is done.
between the experience both myself and my friend have, I'm pretty sure we could get that 300cfm number. And after reading your's and JD's comments and doing some research, I'll probably just stick with an aebs type of manifold with a larger TB. Why make things more complicated than they have to be.
Old Dec 24, 2006 | 12:01 PM
  #55
A20A3T's Avatar
ive got the ex-i(canadian version of the lx-i). the head that ive got recieved a 5 angle valve grind, port and polish, port match and basically brand new valve train. so that will help it flow a bit better hopefully. wouldnt ITBs help make more power due to the fact that the total throttle area is well over what a single TB would be? its like a 60mm going againest 4 43mm TBs, so shouldnt the ITBs make more power overall?
Old Dec 26, 2006 | 12:25 AM
  #56
ITBs are about airmass and velocity, comparing total throttle area between pure pulsed flow and mixed pulse-differential flow makes as much sense as comparing dick size with a horse.
Old Dec 27, 2006 | 01:45 AM
  #57
A20A3T's Avatar
good enough... so does the head ive got help out with some airflow if i get a decent B series intake manifold and redrill it for the head?
Old Dec 27, 2006 | 04:53 AM
  #58
Slo_crx1's Avatar
Boost on that motor is the best way for max airflow Iron block, reworked head, and boost...a match made in heaven
Old Dec 28, 2006 | 08:50 PM
  #59
A20A3T's Avatar
thats kinda what i had in mind, but i wanna try ITBs/megasquirt to be different rather then the typical SAFC/BTM
Old Dec 29, 2006 | 04:36 AM
  #60
Slo_crx1's Avatar
I dunno...itb's and boost just sounds like a headache, not just for tuning but as in leaking-wise as well. If it's converted to lx-i (pgm-fi) I think you could run a chipped pm6 on it...both are still pre-obd. Someone correct me if I'm wrong here :P
