made a homemade water sprayer for the FMIC
I would agree. Measuring the outside temp dosent prove anything.
On a dyno it wouldnt work again. Cause the car wasnt moving.
We hooked up a bead Thermocouple and got a defnite drop in intake charge temp.
THe bead was placed just after the IC. 10-15 Deg C. So basiclly your improving your intercooler effiency. This should give you an aditional 3-5 BHP easy.
If you have a top mount IC like we do in this pic.
You could pack it with dry ice just before you did your run.
ALso since its top mount no chance of watter hiting the mani.
I wont mind two if you can spare em. Will pay for shiping.
forget everything. On a hot day. Hit the sprayer. You will just feel it on your butt dyno. The gains are pretty obvious. At least in our climate.
those should be my last two.
Originally Posted by sixsick6
I used a digital pyrometer on one of my friends high dollar NTX Ntercooler spray kit. He bought it for $400 and you know how much nitrous costs. With my pyrometer (laser) I held it in position while he hit the button for roughly 20 seconds. It never read lower than 2º difference and this was when the intercooler was cool already and the car hadn't been run for hours.
Silly ricer
Good pictures and write up, although I've done this back in 1992 lol
Silly ricer
You're forgetting that an NTX Ntercooler unit is a surface sprayer anyways. If it only cools the surface 2º, it ain't gonna cool the inside much more. As said, the temp drop was measured after the sprayer had been on for a good 20 seconds. if it isn't going to cool it by then, it ain't gonna cool it afterwards either. As said, an expensive waste of money and a waste of nitrous that could go where it belongs, in the engine.
On the other hand, a cheaply done water/alcohol sprayer unit is more than useful, especially since it costs about $350 less. Eery sprayer that I have ever made has cost me around $15. My point is that the high dollar units are nothing but a gimmick.
That logic is still flawed.
Try this spray your tea-shirt. Sit arround do you feel cold.
now go for a spin on your bike. With the wet te-shirt big difirence.
But yeah anything more than watter or ice is a waste of time.
i got tired of the switch so i hooked it up to my vtec solinoid and too make sure i know when it's spraying i hooked up a led to it and put it in one of the unused panels. everything works pretty good so far. i keep a gatorade bottle with some ice and water in the fridge so it will be really cold when i use it but my chic keeps drinking it
. maybe i should add somethign to make it taste nasty
. j/p
. j/p
