Old Oct 14, 2005 | 01:07 AM
  #41
38927's Avatar
Yeah plz fix the pix, or email em to 38927@whoever.com
Old Oct 15, 2005 | 01:29 PM
  #42
racerex's Avatar
This being HMT and all I think its time to slap together a pump system using an old emissions pump. Anyone do this or know of someone who has? I'm thinking you could get the pump relatively cheap at a junkyard and the rest is all tried and true. The only thing that I don't know about is the vacuum created by these emissions pumps vs. what would be the ideal vacuum for efficient crankcase evacuation.
Hmm...time to do my homework.
Old Oct 16, 2005 | 04:41 PM
  #43
FooK's Avatar
pictures are back, server might suck *** and be slow tho, cause its my home computer on my cable modem line.
Old Oct 30, 2005 | 11:35 AM
  #44
CivicRacerX7's Avatar
so whats the advantage of doing this?
Old Oct 30, 2005 | 08:19 PM
  #45
solfly's Avatar
read man
regular pcv system only lets the crank case vent in vacuum not in boost
***** lets it vent in both
Old Oct 30, 2005 | 10:23 PM
  #46
FooK's Avatar
crankcase pressure is hard on pistons and rings.
a stock pcv system allows air to be pulled from the crankcase by engine vacuum. when in boost there is no engine vacuum obviously, so you tap into the pre-turbo intake, which during boost will create a vacuum source to pull the crankcase pressure and vapors out. you incorporate the two pcv/check valves so that the regular vacuum source closes during boost, and so that the turbo intake source closes during vacuum. incorporating a catchcan into this simply catches the vapors so they dont end up sucked into your intake manifold or into your turbo.
make sense?
Old Nov 1, 2005 | 10:58 PM
  #47
B16CRXT's Avatar
so doing this ***** way with another pcv valve at the hose going to teh air intake, flipped the opposite way asnormal, will make this work properly? And putting a catch can in-line between that pcv valve and the intake will keep you from sucking all that oil back into the motor (which causes detonation)......right?
I need to do a setup like this very soon. I think crankcase pressure is causing my front and rear main seals to leak...
Old Nov 13, 2005 | 05:39 PM
  #48
FooK's Avatar
you've got the right idea.
oil in the cylinders greatly increases chances of knock, boombabba boom. I added a diagram that will hopefully clear some confusion.
Old Nov 14, 2005 | 02:16 AM
  #49
crxSIb16T's Avatar
is this necissary for low boost application, around 7 lbs?
Old Nov 14, 2005 | 10:43 AM
  #50
B16CRXT's Avatar
couldnt hurt. at 8 lbs, oil was getting by my front main seal.
