Filling Block... How To.... UPDATED
Old Mar 16, 2005 | 03:56 PM
  #41
Default Re: Filling Block..... How To
you have to make a relationship w/ a machine shop to get good prices. Bring in a couple blocks/heads and watch the prices drop
Old Mar 16, 2005 | 11:18 PM
  #42
crx304's Avatar
i just take them thru the back door! i love my friends!
Old Mar 17, 2005 | 06:01 PM
  #43
absolutezroo's Avatar
i have a buddy that works in a machine shop but the do all manufacturing sort of parts..they make airplane parts and its all CNC so they do hundreds at a time..
Old Mar 20, 2005 | 07:32 AM
  #44
tranceminister's Avatar
CRX304, any dyno testing planned for this. Maybe eventually when you upgrade your turbo? I'm seriously considering doing this to a spare B18b block and am curious to know how well it will hold up. I'm not asking anyone to go blow their engine up on a dyno for testing, but I'd like to see some dyno sheets of filled blocks and at what pressures these things can handle.
Old Mar 20, 2005 | 08:59 AM
  #45
crx304's Avatar
this comming friday i'm hitting the dyno
Old Mar 29, 2005 | 01:40 PM
  #46
TorganFM's Avatar
Check out your local Napa. The small rinky dink place by my house has a machine shop in the back that's 3x the size of the store and when I went in there the floor was covered with tagged blocks and heads either waiting to be worked on or finished. The prices at Napa are also pretty damn good, much better than a lot of speed shops charge for labor alone.
Old Mar 29, 2005 | 02:11 PM
  #47
whiterice's Avatar
Originally Posted by absolutezroo
i'm gonna use the block filler that summit racing sells...is it basically the same stuff?? i know it's a few buck cheaper so i didn't know if there's much of a difference in contents
The two at summit are for cast iron blocks. The have " an expansion rate very similiar to cast iron".
Old Mar 29, 2005 | 03:19 PM
  #48
TorganFM's Avatar
Which expands at a rate most similar to stock sleeves, aluminum or cast iron?
Old Mar 30, 2005 | 10:40 AM
  #49
gordo172's Avatar
so then i would use the one from summit for the f22b2 block right?
Old Mar 30, 2005 | 12:26 PM
  #50
whiterice's Avatar
the aluminum block is getting filled so you would use the aluminum filler. the filler is not attaching to the iron sleeves.
