LS Rod Swap.... How To
Old Mar 8, 2005 | 08:05 PM
crx304's Avatar
ahem....
when it comes to machining engine internals that are going to be turning at warp speed, DO NOT TAKE ANYONES ADVICE!!!!
1) measure twice
2) compare the two rods
3) subtract the bigger from the smaller
4) divide by two
5) machine each side w/ #4's answer
mike
Old Mar 8, 2005 | 11:37 PM
Xgenturbo's Avatar
Originally Posted by jecu
but its says you can get the ones with the 21mm pin that will match the LS rod perfectly. Ill take your advice on the .175" thanks
Like he said, dont take my advice, you never know, I just said it should be around that. but dont just go telling the machine shop to take off .20 either or you'll be throwing out a set of rods. and ask FJT off HT he sells vitara pistons with pins, the pins are the same as the Stock D16 pins.
Old Mar 9, 2005 | 11:40 AM
jecu's Avatar
yeah I know to measure it twice, I was just going to use your measurements for reference. So are all the Vitaras 19mm bc one that site it says that the 98-00 you could get them in 21mm to match exactly. I just wanted to do that bc I emailed Crower asking about the bushings and they have yet to email me back .
Old Mar 9, 2005 | 01:41 PM
Xgenturbo's Avatar
show me a link to where you got the info.
Old Mar 9, 2005 | 03:56 PM
jecu's Avatar
Ill try to find it again, Ill post it up as soon as i get it.
Alright heres the link. They say that you have to bush the end of the LS rod then about half way down the page they mention a certain piston that uses the 21mm pin and the LS rod then wouldnt need to be bushed.
http://www.knology.net/~jediklc/pistonnotes.htm
Old Mar 9, 2005 | 04:53 PM
Xgenturbo's Avatar
Interesting.
Old Mar 9, 2005 | 07:09 PM
crx304's Avatar
here's something interesting that i found out from Crower:
i was just going to order the set of machined bushings for $40. and he was very reluctant on selling them to me. the reason (what he told me) is that ppl were ------- them up as they were putting them in, then calling back and bitching.. so i just bought 12" of silicone bronze from their source.
and yes i fucked 1 up pressing it into the rod, and fucked 2 other ones up reaming them on the drill press ( betweeen 2 sets of rods)
just FYI
Old Mar 9, 2005 | 07:48 PM
Xgenturbo's Avatar
just FYI
We actually reamed mine on a lathe, and then pressed them in and then chamfered them. they work great and the pin has a nice interferance fit, would you suggest I drill a hole on top of the rod head for oil?
Old Mar 9, 2005 | 08:35 PM
jecu's Avatar
just FYI
well damn that burst my bubble all to ---- . Maybe I can still get them to sell them to me.
Old Mar 9, 2005 | 09:52 PM
crx304's Avatar
honestly, i wouldnt worry about it,
i didn't
just make sure that you use a good assembly lube when you put it all back together
jecu....
go ahead and talk to the guy. but be warned.... "when you press those bushings in, make sure those ----------ers are straight". and use oil to help them glide in.
