Poor Man's exhaust cut-out
Old Apr 14, 2008 | 02:22 PM
EG-prince's Avatar
Default Re: Poor Man's exhaust cut-out
Originally Posted by SloS13
lulz that would suck. Nope, the cable housing isnt coated in...anything so you get that nice metal-on-metal fritction. Stays open just fine.
How do you close it then?
Old Apr 14, 2008 | 02:53 PM
beaker's Avatar
heres a good idea with no effort put into a diagram...
l __l
l C__ <------ you pull the wire up, hook the black top over this and, still retain the spring action in the TB. that way
l_____l that way when you want it to close, you just slide the wire out of the whatever the ---- you want to call it
Old Apr 14, 2008 | 03:00 PM
igotnothin's Avatar
^^^^ i know what you mean,,, but your diagram in no way helps you ilustrate what you are saying...
Old Apr 14, 2008 | 05:41 PM
idiot-stick's Avatar
push the lever. To open, pull the lever. I removed the throttle return spring and the spring on the other side of the butterfly. The tiny spring pictured isnt even necessary after I tweaked it.
Basically the friction in the cable keeps it open. It's a hard wire in the center with a metal sheathing, no teflon, plastic, etc.
Old Apr 15, 2008 | 11:28 PM
boosted97civic's Avatar
great idea
Old Apr 15, 2008 | 11:52 PM
turborex89's Avatar
haha nice
Old Apr 16, 2008 | 01:31 AM
EG-prince's Avatar
It would be neato to use your ebrake as the lever, but then you would have to not have a functional ebrake anymore
Old Apr 16, 2008 | 06:55 AM
#Rotor's Avatar
one can see who here does not have a clue when it comes to old school side-draught carbs with mechanical chokes,CHOKE CABLES and whatnot....
it's all fancy smancy drive by wire these days... HMT's worst nightmare...
the cable itself is actually a very stiff solid wire, it does not slide loosely in the sleeve, so you can pull something open with it, and then push it closed again. If it does not pull back very hard, it will stay open... almost like what gearshift cables do... actually exactly like that, just smaller.
Old Apr 17, 2008 | 01:41 AM
volumeking333's Avatar
A guy that i met locally used a trailblazer Drive by wire throttle body wired to a switch (fully open/fully closed) as an exhaust cutout in a turbo cavalier, worked great until his wife drove the car in the snow with it wide open for a long time
Old Apr 17, 2008 | 06:55 PM
CXyD's Avatar
How about wiring the fly by wire throttle body to a full throttle switch.
Isn't that some of the C6 vettes do it?
