How about a REAL discussion about LS rod bolts?
Old Apr 19, 2007 | 03:13 AM
Default Re: How about a REAL discussion about LS rod bolts?
Toplines!
Old Apr 19, 2007 | 03:31 AM
0b00st0's Avatar
Originally Posted by chris
I wanna say nippon was making or makes these.
Eh, it doesn't matter.
Old Apr 19, 2007 | 04:08 AM
Guess I was just trying to state that they are just grossly overpriced has the 81mm are like 130-150 so yuppers
Old Apr 19, 2007 | 04:27 AM
0b00st0's Avatar
Big time. They used to be a lot cheaper.
Old Apr 19, 2007 | 10:19 AM
Jcushing's Avatar
if your rebuilding the engine its hard to not use arp rod bolts, i mean they are like upwards of 35 bux... the biggest factor in installing them is resizing the rod but i had that done anyway for my new bearings...
if your NA then chances are your prolly dropping in some higher compression pistons so why not new bearings/arp rod bolts...
if your boosted then chances are you want to put in stronger rods/pistons basically eliminating the whole question.
i dunno, i mean theres some things to cheap out on but i just dont see the point IF your opening the bottom end anyway...
Old Apr 19, 2007 | 02:33 PM
noboostedEGo's Avatar
Lots of great discussion!
I just picked up a spare ls longblock a guy owed me yesterday....and i'm thinkin about going lsv with some tt rods (what kind of forged pistons would you guys go with for EDIT: a BUDGET na build?) etc. and have a fun sorta quick dd out of it.
Old Apr 19, 2007 | 05:40 PM
Jcushing's Avatar
for a budget NA build use stock rods arp rod bolts and jdm ITR pistons and ACL race bearings
oh and i have the RS machines 84.5mm ITR pistons, they work really good...
Old Apr 19, 2007 | 07:18 PM
how about budget forged?
srp's? or just shell out a tad more and go with cp/wiseco?
only the srp's are budget....but i'm still asking.
Old Apr 19, 2007 | 07:39 PM
JDMFantasy2K's Avatar
well while were at it b20's especially b20b's are basically being handed out at importers these days low mileage much less than your typical ls block but then you have issues with the sleeves.
thought sleeve issues usually only happened when they're boosted. I know they siamesed the middle cylinders but how much of a problem is it when you just slap a vtec head on it?
Old Apr 19, 2007 | 08:43 PM
Jcushing's Avatar
whats wrong with cast? you could spend 200 bux on a set of cast type R clones and keep the stock rods or run forged for 500ish and spend another 250 on rods... hmmmm
