Homemade Boost control at it's finest...
Old Feb 15, 2007 | 09:43 AM
Racintweek's Avatar
Default Re: Homemade Boost control at it's finest...
Old Feb 15, 2007 | 09:50 AM
Speed Phreak's Avatar
Originally Posted by Ogubudiah
no, I was refering to his real-time ems...the a/f is tuned, but what about ignition.
thats all.
I have control over the ignition map as well, I can retard timing per PSI of boost I'm running. If you've ever used Crome, Ghettodyne, Turboedit, ect that should give you an idea about what I'm saying.
Originally Posted by Racintweek
most people using junkyard turbo's need more than the 5-7psi the stock WG comes with, but if someone is using an external unit you could leave it out
i know there is a VW part that you can use for the electronic 1-way valve but i have to remember the part number. they are like $10 at the dealer and can hold ~35psi,much more than what 99% of people need
EF's are the ---- in camo. and is that an Si seat in front of the tires in the first pic??
I'm running an HX35, the king of all junk yard turbo's ...so my 6~7psi external gate spring is plenty for low boost. But I see what you're saying about the smaller junyard turbo's.
The honda/acura PCS/ECS i'm refering to can be used the same way as your 1-way valve....
No those are 92-95 seats...I do have a mint 90-91 Si seat in the shop tho
you could run a non-vtec mtor with the v-tec maps for high boost w/ diff ignition timing and to switch on the hi-boost based on MPH
What if you're running a VTEC engine ?.....
The point is you don't NEED different maps for high and low boost. The ECU knows what it see's above WOT, be it 1psi or 20psi. Most aftermarket EMS' and "chipped" factory ECU programs know how to compensate for different levels of boost, mostly just due to the nature of how the sensors feeding the ECU work. So long as you don't run into the mechanical limitations of those sensors, and have taken the time to properly tune the entire boost range you are running.....there is no need to switch to a different fuel/ignition map just because you're running more boost.
....Unless you run into detonation in the higher horsepower range( and need to switch to a different fuel) of course
Old Feb 15, 2007 | 10:44 AM
whiterice's Avatar
Great write-up. This is how it should be done. Picture(s), diagram(s), and part number(s).
Old Feb 15, 2007 | 11:50 AM
Racintweek's Avatar
Old Feb 15, 2007 | 12:07 PM
Minor Threat's Avatar
can you activate the IAB's with MPH insted of RPM?? (might be a dumb ? but i run an LS) if so you could use that for activating hi-boost
http://forum.pgmfi.org/viewtopic.php...t=speed+output
Old Feb 15, 2007 | 11:25 PM
Originally Posted by Speedy via email
What happened to HMT ?... It used to be full of intelligent people. My boost
control thread is inundated with questions about fuel and ignition maps.
Great job of encouraging him to post more tech up, guys, it's hard enough to browbeat him into posting to a forum where he's understood and appreciated.
If you have zero ------- clue about how a standalone works you need to read the stickies in the Engine Management forum, get the ---- out of this thread.
Old Feb 16, 2007 | 10:07 AM
Racintweek's Avatar
my useless posts are gone, only my archaic picture remains
Old Feb 20, 2007 | 09:10 AM
ifly87's Avatar
Very good idea!! nice to see people are still contributing to this site like this.
Old Feb 25, 2007 | 01:48 PM
Chiovnidca's Avatar
I like it!!! Think i'll give it a try. Where did you find those 1/4 x 1/8 fittings?
Old Feb 25, 2007 | 04:27 PM
Reread the original part, Chiovnidca, he says where and gives a part number, too.
