Old Oct 5, 2010 | 04:18 PM
  #241
neilandbob's Avatar
This is a top thread. Cool work, glad you didn't give up on it!
Old Oct 5, 2010 | 08:40 PM
  #242
josh19wrc's Avatar
thanks guys!
Got a throttle cable hooked up finally. hooked up the IAC valve, it lights right off now. Turned the main fuel trim down, which works great at idle, but, it stumbles when you dip into the throttle now... I will have to turn it back up, and trim out the fuel at the idle points in the fuel curve. Also discovered that BOTH valve covers are leaking, BAD. Awesome. That'll be fun to fix with the turbos directly over both
Old Oct 18, 2010 | 04:40 PM
  #243
DreamworldUC's Avatar
Great work can't wait to see it finished
Old Oct 19, 2010 | 03:11 PM
  #244
boosted-t's Avatar
lookin really good man,i cant wait to see some numbers
Old Sep 1, 2011 | 10:06 AM
  #245
whats the status on this build? been wanting to see this for a while. no posts in almost a year.......
Old Sep 7, 2011 | 12:33 PM
  #246
josh19wrc's Avatar
Got the rig finished, but, not in a way that I anticipated. I had a multitude of problems with the V8, so I got fed up and yanked it out. Whoever runs the universe agreed with me and threw me a bone. I found a Cummins 4BT 4L turbodiesel for 1200 bucks, which is a steal. I plunked that down in there, and she is putting out around 150HP, 400 ft-lb of torque and get 18MPG. It has been running for about 3 months now with no major issues:
Old video, back when I first got it running... no throttle pedal even yet!
Attached Thumbnails Power Wagon Rebuild (Update: 11/5/08)-img_9783.jpg   Power Wagon Rebuild (Update: 11/5/08)-img_9784.jpg   Power Wagon Rebuild (Update: 11/5/08)-img_9785.jpg   Power Wagon Rebuild (Update: 11/5/08)-img_9787.jpg   Power Wagon Rebuild (Update: 11/5/08)-img_9791.jpg
Power Wagon Rebuild (Update: 11/5/08)-th_img_1136.jpg
Old Sep 7, 2011 | 12:35 PM
  #247
josh19wrc's Avatar
Oh, and is still turbo, as you can tell from the pictures!! Running an HX35 off a 6 cylinder Dodge Cummins truck, with upgraded fuel pin, intercoolers, and the pump turned up some:
http://www.pirate4x4.com/forum/showthread.php?t=980455
Old Sep 7, 2011 | 08:14 PM
  #248
HMT-Roger's Avatar
How long did it take for you to do this? Love the pics by the way!
Old Sep 8, 2011 | 06:34 AM
  #249
awesome! really wanted to see that twin turbo/supercharger setup running but awesome none the less.
enjoy!
Old Dec 10, 2011 | 02:27 AM
  #250
DunKrS's Avatar
Beautiful work man, what is it you do for a living? The big block was amazing, but the 4bt seems much more simple and easier to work on should the need arise. I was so glad to see you keep mopar with mopar instead of the hacks the decide a 350 swap is a good idea in a power wagon =/ Beautiful truck, I applaud your clean, tidy, and done right style of work! Keep it up! =)
krustindumm
Jul 12, 2006 10:47 PM
Gavin
Aug 19, 2005 10:12 AM
