Jeep YJ 4.0 Turbo-Dyno video added
Old Dec 26, 2008 | 01:10 AM
stillnoturbo's Avatar
Default Re: Jeep YJ 4.0 Turbo
Originally Posted by CSaddict
Am I chewing on my finger?
I thought it looked like you were sniffing your fingers also.
Old Dec 28, 2008 | 06:53 PM
rosario4124's Avatar
Originally Posted by highroller54
I thought you were smelling your fingers
Old Dec 28, 2008 | 08:16 PM
Maybe his fingers went through the toilet paper and he had something really good to eat before hand and was wondering if it still smelled the same? Not saying I ever did this.
Old Dec 29, 2008 | 01:19 PM
Econo-Box's Avatar
Looks like hes worried abotu his current line lol.
Old Dec 29, 2008 | 06:55 PM
SpankedYA!'s Avatar
I wasn't worried. That was the easy trail. It was later in the day that truck took on all sorts of damage.
Old Jan 5, 2009 | 06:41 PM
daubleaaron's Avatar
any dyno numbers yet? I like yj's
Old Jan 5, 2009 | 09:13 PM
SpankedYA!'s Avatar
I rode in it on Friday with the 3" exhaust on it. It pulls very well but Im sure its very rich. We put my 14:1 FMU on it.
Old Jan 7, 2009 | 10:29 PM
saabturbo's Avatar
ordered the wideband the other day, soon as that shows up and is put in I need to figure what the air/fuel looks like and might need to swap out the fmu. I was talking to dave the other day and we might need to trick the TPS into thinking its at WOT at just a few PSI because the ECU is pulling injectors when it is not at WOT
Old Jan 8, 2009 | 12:04 AM
SpankedYA!'s Avatar
Joseph Davis is credited with that trick if it works. I got the adjustable hobb switch today and a new map sensor.
Old Jan 18, 2009 | 12:59 PM
saabturbo's Avatar
well it works. I did the wiring this weekend on my Jeep and it ended up using a rheostat to adjust the voltage going into the reference line on the TPS. when i hit 2 psi the hobbs switch clicks and kicks the 5 volt wire down to 3.65v before it gets to the reference line and kicks it into open loop. So far so good, it is working well. running a little rich, around 10.5 so now I need to mess with the FMU.
