SOHC ZC VTEC 1.5 OR 1.6 ?
Old Jan 8, 2003 | 01:12 AM
Default Re:SOHC ZC VTEC 1.5 OR 1.6 ?
I'll try to take some pics of the swap i did for a guy about a month ago. Installed the sohc zc vtec motor and the vti lsd tranny.
Old Jan 8, 2003 | 01:32 AM
HMT-Admin's Avatar
Administrator
thats great info chris, so these are all obvisouly going to be OBD1 engines, and they came from what model?
I'm guessing the pistons are not domed in this version of the ZC.. any ideas?
when you refer to the LSD tranny the vti, that is also for 5g civics correct? using hydro? Do you know the gear ratios?
Jeff
Old Jan 8, 2003 | 03:35 AM
http://www.vtec.net/articles/view-ar...rticle_id=7367
Has all the models that came with the zc vtec motor. I have yet to pull a head off one of them but it may. So many jdm motors have slightly higher comp. so that's where the extra power comes from.Vti Lsd tranny has the same gearing has an ex/si tranny.yes it's for a 5th gen hydro. Alot of importers down here in so.cal are selling them for dirt cheap. got one for 200 bucks. trips people out. A d series LSD. Just wanted to also say great site. I'm finishing up a turbo kit now with alot of info and ideas coming from your projects. Thanks and keep up the good work.
Old Jan 8, 2003 | 04:33 AM
rc51's Avatar
Thats a great link! now I know for sure my egine is a 1.6l cause the other zc 1.5L are label as d15b vtec mine just says "zc" and the link you gave has the proof I needed it clearly says "ZC VTEC 1590cc SOHC VTEC, 130ps" can't wait till my turbo kit is finish, like to see how this baby pulls. peace out
Old Jan 8, 2003 | 04:45 AM
rc51's Avatar
Originally Posted by AbaZ
interesting... I knew their was d15 vtec's, and d14's I drove a few while I was on my trip to Ireland. So it looks like the OBD1 SOHC ZC did come in vtec then eh.. wow, guess you learn something everyday
I still would like to see one..
Jeff
Yeah...I just drop this motor in 6 months ago and never got any real info on the block all I knew was that its say's "zc" on the block. evreyone here has answer some of my question but one still remaining is welther this is a 1.6 or 1.5 but some link I check from chris post http://www.vtec.net/articles/view-ar...rticle_id=7367
shows a ZC VTEC 1590cc SOHC VTEC, 130ps which is a 1.6l and
D15B 1493cc SOHC VTEC, 130ps which is a 1.5l same hp but more torqe on the 1590cc I'm assuming? can some one confirm this? peace out.
Old Jan 8, 2003 | 04:50 AM
rc51's Avatar
Hey Chris do you have any info on where and how I can get one of those lsd "D" series tranny, thanks. I will try to get some pic's this week and post them up fo ya ta see. latez.
Old Jan 8, 2003 | 03:56 PM
HMT-Admin's Avatar
Administrator
Some parts are interchangeable. The heads on a d15/d16 are going to be similar, (if they are 16 valves)
Comparing
d15b2 & d16a6
Both use the same head, the d15 has a slightly weaker camshaft, but the entire valve train is the same.
bottom end parts are different. The DX has a shorter stroke than the a6. So crank and other parts are not swapable. The bore size of the pistons is the same. But if you buy a6 pistons for you dx, you are going to be getting a different compression. I dont know what the exact formula is.
Jeff
Old Jan 8, 2003 | 09:11 PM
I need to find the # of the imoporter. E-mail me at -------------------- for the contact info.
Old Jan 8, 2003 | 09:58 PM
hybridcrx's Avatar
Hey, I'm running the D15B VTEC in mine. It's running to full potential since right now I'm using a PM6 w/RPM activated switch with a DX tranny. Here's a pic:
http://image1ex.villagephotos.com/pu...sp?id_=1141919
Pic of engine code:
http://image1ex.villagephotos.com/pu...sp?id_=1038997
