How about a REAL discussion about LS rod bolts?
Old Apr 18, 2007 | 10:33 AM
noboostedEGo's Avatar
Default Re: How about a REAL discussion about LS rod bolts?
Thanks guys for all the great info so far! It's exactly the kind of discussion I was looking for.
HiProfile, when you say the motor threw a rod, would that be a result of anything with the rod bolts? Thanks for you personal experience.
B20Pete, your experience is quite helpful.
Old Apr 18, 2007 | 10:49 AM
Slo_crx1's Avatar
I look at it more as peace of mind, to reiterate on what Chris said. These motors are getting old. You wouldn't got out and spend the money for a factory turbo'd porsche and then run regular in the tank, kind of the same deal here.
Old Apr 18, 2007 | 11:34 AM
I agree, slo, it isn't like ARP is expensive either. My stance on the subject is that bad tech like this is the product of illogical thought processes and bandwagoning. Both are counter productive; while these engines are getting old and any serious (even budget) build will use ARP or better yet TT rods, if your mind is trained to follow other people's illogical thought processes instead of thinking for yourself then your build will be flawed. Unless you follow HT doctrine of "replace everything at top dollar prices because I'm too stupid to think," of course.
Old Apr 19, 2007 | 01:07 AM
Slo_crx1's Avatar
You make a valid point. In all honesty I can say I've never seen a stock LS rod bolt break, most I've seen is a stretched out rod end from a brutal missed downshift.
Old Apr 19, 2007 | 01:37 AM
Originally Posted by HiProfile
I too know a guy who builds engines as his job. IIRC he had a B20/vtec with ITR pistons and thats about it. Revved to 8500+ each day...after it warmed up. Beat the **** out of it. The motor eventually threw a rod, actually, albeit it was a stock (and likely reused) fastener, as he gets b20's for nothing. I guess my point is that not all rods or conditions are created equal. But I'm entirely sold on the idea that most broken engines are from user error durring assembly.
BTW JD, I'm curious about your 'big end' statement. All d16/b16/b18's have the same rod journal size of 48mm. Its the width that is different - B18a/b,B20,B16 are widest, then d16's, then b18cX's. At least says my info sheet. I can't see it being wrong in many spots though, everything I've been able to check is correct.
itr pistons in a b20 huh. 3mm difference in piston to bore there seems like it might be an issue
Old Apr 19, 2007 | 02:07 AM
Slo_crx1's Avatar
Good eyes...I missed that one completely
Old Apr 19, 2007 | 02:11 AM
well while were at it b20's especially b20b's are basically being handed out at importers these days low mileage much less than your typical ls block but then you have issues with the sleeves.
Old Apr 19, 2007 | 02:30 AM
B20Pete's Avatar
The ONLY way I could even think that is legit is if that builder used the ITR spec RC Eng pistons for his B20.
Other than that, his IIRC could only be good if he was using muffler spacers around the piston so he wouldn't get blow by. You can get those @ most Import Shops nowadays & they sell them in sets of 4.
Old Apr 19, 2007 | 02:45 AM
0b00st0's Avatar
http://www.ericksracing.com/id175.html
ITR spec pistons have been made in a number of sizes for years now.
Still, I don't think that's what he was referring too.
Old Apr 19, 2007 | 02:55 AM
I wanna say nippon was making or makes these.
