B18a1 pistons STOCK vs. FoRGED
Old Dec 6, 2006 | 05:21 PM
absolutezroo's Avatar
Default Re: B18a1 pistons STOCK vs. FoRGED
Originally Posted by Racintweek
power kills rods
a bad tune melts pistons
Exactly.
Old Dec 6, 2006 | 05:28 PM
Xgenturbo's Avatar
Originally Posted by IowaTCoupe
Edit: Meant for PM not post reply :1
and in reply to other guy above... nope, i have no idea what i'm doing with 400whp... i have no idea how to tune either? (Sarcasm) i just taught the guy who owned the dyno and "rebuilds" hondas.
Just want to know the limits of the stock pistons, because the Vitara cast pistons in the D series have pushed over 400hp... and i'm ignorant to the B pistons tolerances.
Well let me put it this way, a guy I know is making 334whp on his stock B16 with a good dyno tune. how long will it hold that power? well if the timing stays the same and the tune stays the same then the only thing that can go wrong is the rods wont be able to hold the power and eventually weaken and snap.
EDIT:
You come on here asking how much power a stock piston will handle, meaning you want more than 200~250whp, in this case why not just dish out the extra $300 and get forged pistons? just a logical thought.
Old Dec 6, 2006 | 06:12 PM
Slo_crx1's Avatar
Detonation is the biggest killer on any Honda cast piston...even the b-series ones. Your ringlands will be the first things to go (they still sit high just like the d-series ones do), and if the combustion chamber temps get hot enough, it will start to melt them. I've nuked a couple of b18 pistons on conservative setups, one was due to shitty fuel and started pinging, and I'm pretty sure the others just saw too much heat from too small/inefficient turbo setups. If you're one the road to 400+hp, then stock cast pistons is not the vehicle to get you there.
Old Dec 6, 2006 | 06:45 PM
IowaTCoupe's Avatar
I'm debating if i can go stock pistons only because im broke, and It's 3 weeks before xmas~~~ Can't spend too much $ on myself...
Hypothetical situation:
I have tuner toy H rods, or Eagle H beams...
Stock B18 pistons (9.7:1 C/R)
Felpro (stock) headgasket, so i'm not lowering c/r or double decking the headgasket
running 20psi tuned right... no detonation... with 93 octane
Would the pistons hold? I'm more worried about the Rods... i'm 90% sure i'm goin w/ TT rods for $225.
Will i be a first to push the limits of stock pistons? (w/ H beam rods)?
Cliff Notes: Although it's not advisable to push stock pistons, has anyone done it, and what did they handle? what are they still running?
Old Dec 6, 2006 | 09:05 PM
if you can keep heat and detonationi under control the stockers might sufice.
Old Dec 6, 2006 | 09:12 PM
EG-prince's Avatar
even besides the stock pistons holding, the rings and ringlands are very likely to let loose at that high of cylinder pressures. haha but thats coming from the guy trying to sell you pistons and rings
Old Dec 6, 2006 | 09:30 PM
ghettoturbo gives the best advice here...do it all or leave it alone.
