Filling Block... How To.... UPDATED
Old Mar 6, 2005 | 11:25 PM
crx304's Avatar
Default Re: Filling Block..... How To
step 3
Old Mar 7, 2005 | 12:26 AM
turboDA6's Avatar
hmm another dumb questions. how far down do you fill with the block filler? i kno how far from the top but how far down do you go?
Old Mar 7, 2005 | 09:07 AM
slowpoke's Avatar
So what are the positive benefits of this vs... running a blockgaurd.
Old Mar 7, 2005 | 10:10 AM
Foowee's Avatar
A block guard supports the sleeves in the wrong place, the top. Cylinders need support where lateral loading is greatist, the middle. Blockguards hinder heat transfer where you need it most, at the top.
Old Mar 7, 2005 | 08:59 PM
crx304's Avatar
exactly, the point that the cyl walls need the most support is in the upper 2 inches. but we are limited to that on the filling process to 1 1/2 inch below the deck because of the water pump.
check out www.theoldone.com and search for "block posting" larry is a honda genius and gives a write up on the block posting procedure, and the weak points of the honda block.
i posted my first block and had absolutely no problems w/ it @ 15psi. but the head-lifting owned me.
i just decided to do the filler to see how it works.... i know.... kinda crazy, but what the hell, right? someones gotta give some real world testing feedback.
hey whitey, how bout a sticky?
mike
Old Mar 7, 2005 | 11:26 PM
Jeez I'm the mod here . Another nice write up.
Old Mar 8, 2005 | 08:10 PM
crx304's Avatar
oops, sorry chris.... forgot that i was'nt in GD
just wait till i do the write up on the "easy to read honda compressor maps"
you muthafuckas are gonna flip!
late
mike
Old Mar 8, 2005 | 09:03 PM
raiden571's Avatar
do you thinking combining blockposts and the filler would have any positive affects? me and my brother want to do a ghetto d15 build this summer for fun, just looking for different options
Old Mar 8, 2005 | 10:05 PM
themadhatter's Avatar
it might block water flow if you use the post and filler if the water passages where in the way of the post but you bastered you trying to copy me i'm doing a getto d15 build this summer lol but any way do you thank it took over a gallon to do the block?
Old Mar 8, 2005 | 10:12 PM
crx304's Avatar
woah, whoa!!!!!!!
a gallon? you are only suppose to fill the upper 1 1/2 inches of the cylinder walls !!!!!!!!!!!!!!!
that's like 1 cup of filler!
go rearead the how-to
