ball bearing turbo oil supply
Old May 19, 2012 | 05:02 PM
Roadrunner's Avatar
Originally Posted by ghettoturbo
...might want to talk to the turbo manufacturer before you do anything. Some already have a restrictor built in and cutting oil flow more could cause damage.
-Jay
Thanks for the tip Jay, I recently had a close look at the turbo, there is no shaft play at all, vertical or lateral, yet I'm getting a small amount of oil out of the turbo outlet pipe when I hold the engine at about 2500 revs. The crankcase ventilation system was disconnected when I did this test, so the oil has to be coming from the turbo compressor shaft, which is strange for a turbo thats in such good nick, and it's also a water cooled turbo on a diesel engine which should keep shaft/bearing/seal temperatures down to a safe level! Excessive oil pressure/flow is the most likely culprit here, but I'm open to other views!
valkyie
Nov 26, 2010 06:52 AM
excivic93
Sep 16, 2007 09:16 AM
Bird333
Jan 6, 2006 05:49 PM
sgoertz
Nov 8, 2005 02:16 PM
CivicDragon916
Aug 24, 2003 02:53 AM
