Turbo Yamaha Snowmobile
Old Sep 13, 2011 | 07:48 AM
tjc's Avatar
tjc
i was contemplating not using an intercooler for response... I will keep it around 6 psi anyway. My nytro is a 2008.
Old Dec 5, 2011 | 07:54 AM
tjc's Avatar
tjc
Originally Posted by john0270
Take a look at the MCX 180 kit for the nytro. Stock fuel pump is used in the 240hp kit with a set of umbrella injectors. I have installed the 180(6psi), 240(12psi) and 270(16psi) kits from them. the 180 kit doesn't use an inter cooler, the response is quite a bit quicker than the other two that do have an inter cooler. If you have a 2009-2010 nytro use the yamaha 8bu weights, two 17mm steel rivets in each and 14.5mm rollers with stock clutch springs, works just great with the 180 kit, and you don't have massive weights that have a hard time back shifting like with the other levels of hp.
Im used to the ski doo clutching, Im new to yamaha. According to the manual there are two different weights on the steel rivets. Is it the 3.6 oz or 4.5 oz?
Im getting close with this thing. Another good day and I will be just about done.
Old Dec 5, 2011 | 08:55 AM
awesome. what fuel control did you end up going with? add more pics. cant wait to see vids.
Old Dec 5, 2011 | 09:03 AM
tjc's Avatar
tjc
i ended up scrapping the intercooler and using a charge box. I think with the low temps in the winter and only running 5-6 pounds boost I should be good.
I used a fuel controller for a snowmobile its GEMs piggy back adds fuel under boost only.
Attached Thumbnails Turbo Yamaha Snowmobile-dscf2436.jpg   Turbo Yamaha Snowmobile-dscf2437.jpg   Turbo Yamaha Snowmobile-dscf2432.jpg   Turbo Yamaha Snowmobile-dscf2434.jpg   Turbo Yamaha Snowmobile-dscf2435.jpg
Old Dec 5, 2011 | 09:21 AM
that will work. when is it time for the test ride? cant wait to see this. please tell me you have a camcorder?
Old Dec 5, 2011 | 10:18 AM
tjc's Avatar
tjc
I will work on a video, we prob wont have snow here for a few weeks though. I'm pretty pumped to get it going.
This is a great site, it's a lot more fun to see what everyone is building then to look at a kit that someone bought.
Old Dec 5, 2011 | 07:06 PM
john0270's Avatar
we are using the heavy rivets, your going to have to experiment though
8bu in this list:
http://www.cbperformanceparts.com/pr.../?pcid=196#top
you don't need to use the 14.5mm rollers, but the engagement rpm is a little high without them.
6psi is pushing the stock injector's capacity to the max remember. What are you doing for oil scavenging? Remember the oil pressure port by the sending unit on the block is 1/8-28 BSP, not 1/8th npt. You can however run a BSP die over a NPT fitting and it makes it work.
Old Dec 5, 2011 | 07:25 PM
tjc's Avatar
tjc
I have not picked the scavenge pump. I see powderlites offers a reasonably priced facet pump unit but I am worried about reliability. I dont see myself dropping $500 for the MCX mechanical pump.
I actually ordered the oil fittings today from a shop in the UK they were not easy to find.
I will be in the 5-6 psi area for boost keeping it on the safe side.
Thanks for the help.
Old Dec 24, 2011 | 07:03 PM
tummys10's Avatar
Lovin this build.
Old Dec 26, 2011 | 07:16 PM
tjc's Avatar
tjc
Originally Posted by tummys10
Lovin this build.
thanks man.
So i started the motor today.
Changed the oil, topped off the coolant and ran it.
I need gauges so I have not actually moved it but it ran. It is a little louder than I hoped but I have not put the seat and heat shield over the muffler yet.
Stil waiting for snow........
Attached Thumbnails Turbo Yamaha Snowmobile-dscf2463.jpg   Turbo Yamaha Snowmobile-dscf2464.jpg   Turbo Yamaha Snowmobile-dscf2466.jpg   Turbo Yamaha Snowmobile-dscf2467.jpg
