Old Oct 30, 2008 | 02:32 PM
  #101
aznkr4zyboi's Avatar
Could i run this setup but instead of the slashcut to the downpipe can i run it to the intake?
Attached Thumbnails DIY Two Way PCV System How-To (HoMedepoT style)-catchcan.jpg
Old Oct 30, 2008 | 08:34 PM
  #102
speedjunky01's Avatar
yea aslong as you keep the one way valve
Old Apr 13, 2009 | 11:59 PM
  #103
zero937's Avatar
that some sick ---- nice thinking dude
Old Apr 15, 2009 | 02:42 AM
  #104
turboknightmare's Avatar
these catch can setups drive me crazy, whats the simplest most effective way to do it once I go boost?
Old Apr 24, 2009 | 05:15 PM
  #105
boostcreepin's Avatar
^ ---- simple, when u got the right way in front of u.
Old Jun 3, 2009 | 07:44 PM
  #106
turbo750's Avatar
good write up.
Old Jun 12, 2009 | 07:56 PM
  #107
leitchey's Avatar
what are the best one way valves to use?
Old Feb 15, 2010 | 06:30 PM
  #108
teewakahn's Avatar
Originally Posted by projekteg
just run one of the already mentioned slash cut methods (exhaust or pre turbo intake) and use a baffled catch can in line. oily vapors are going to come out of the crank case regardless, that's why it's best in my opinion to use the exhaust slash cut method. who cares if you get a slight hint of smoke out of the exhaust under boost, it's not like you have to deal with it inside the car, and it's not like it will be so bad you'll have oil dripping in your exhaust or anything.
That exhaust thing wont work if u hav a cat. we need to use some kind of vanturey(sorry spelt wrong) system. use exhaust to make vac. see what i can come up with.
Old Feb 15, 2010 | 06:52 PM
  #109
teewakahn's Avatar
Default PVC system.
Originally Posted by lkailburn
weld in a metal slash cut tube. and attach the hose as far away as you can. they also make a high temp hose that would help in this application. either way you need to use a metal slash cut tube. make sure you put a check valve in this line aswell.
that would only work if it was set up after the cat. would'nt it?
Old Feb 15, 2010 | 06:55 PM
  #110
teewakahn's Avatar
that would only work if it was after the cat.(if u hav one that is).
