LS Rod Swap.... How To
Old Aug 12, 2008 | 01:17 PM
  #101
mike_belben's Avatar
.003 is excessive for an interference fit.. theres no need and you'd have to cook the ---- out of the rod/freeze the bearing to get it in there. the likelyhood of having the rod cool and grab the bushing half way in is very high. .0003" will probably hold adequately, but id say .001-.0015" is about your standard interference.
personally id rather press in a slug or predrilled core, then cut the bronze true in a pin bushing cutter (kinda rare but they hold the rod square by the big end and slide a boring bar with single point cutter through the pin end. engine shops have them.) and then hone to final fit. this way everything is square.
when you have a cocked pin bushing one side of the piston sits higher than the others so really tight head clearances might hit, the sharp edge of the ring face chaffes the cylinder wall, the piston wears all crooked. all kinds of bullshit that lead to an underperformer. nobody likes that.
Old Apr 13, 2009 | 12:27 AM
  #102
tkda's Avatar
sweet!
Old Jul 18, 2009 | 04:20 PM
  #103
ek9561's Avatar
nice work
Old Jul 31, 2009 | 10:05 PM
  #104
crx304's Avatar
re-fer to the original post, and skip all the bullshit
Old Aug 1, 2009 | 03:04 PM
  #105
SoleKing's Avatar
sick
Old Aug 21, 2009 | 10:30 PM
  #106
jdmontheway's Avatar
nice build
Old Oct 8, 2009 | 08:37 AM
  #107
when you say,you cant reuse pistons that have been pressed in before,you mean you cant put them in another block or depress them and press them to other rods?
Old Oct 8, 2009 | 07:54 PM
  #108
Lazysk8r2's Avatar
good write up
Old Oct 8, 2009 | 10:22 PM
  #109
stockandsloweg6's Avatar
bump for you, excellent write up full of good info
Old Jan 4, 2011 | 09:07 PM
  #110
whiterice's Avatar
Quick update. After about 3 years DD, I'm still running on these rods w/ Vitaras
mdotholla
9
Jun 3, 2009 08:34 PM
sikcrx89
1
Aug 7, 2006 07:07 AM
sailman
22
Jun 5, 2006 01:05 AM
