Old Dec 1, 2007 | 06:00 PM
  #91
Chasedezle's Avatar
Home depot is awsome, made me a 4in PVC intake. proforms well and sounds badasss tooo
Old Dec 4, 2007 | 07:17 PM
  #92
E-b0la's Avatar
Nobody cares about your stupid intake, jackass.
Now resize your ------- avatar, tool.
Old Dec 30, 2007 | 01:47 AM
  #93
ONDUHFLO's Avatar
So heres a quick 5 minute diagram of the proper setup according to Projekteg, Its the same as ****'s original idea, but with a check valve on the vent hose between the T-fitting and the IM.
It makes perfect sense to me, but I'm new to this....Can someone with uncontrollable knowledgablilities tell me if this setup is right? Will it work with proper check valves that wont leak?
Old Jan 2, 2008 | 05:53 PM
  #94
bgdriver's Avatar
For those of you asking a catch can set-up should just be considered part of your turbo set-up, period. I just ignored the oil leaks on my car since I've got it until a few days ago, when every oil seal in the car broke (loosing 1.5 quarts every hour) and I was only at 9 psi on cold, cold days. Oh, well at least I get to replace the autozone special clutch while I'm there.
Old Jun 17, 2008 | 09:05 PM
  #95
87crexSi's Avatar
sorry this is years later from the origination date......but is it possible for me to get some workin pix i have what i need to do this yet i have to see a diagram or some pix to fully see how to do it tho that i understand the concept. thanx guys.....
workinman1158@yahoo.com
Old Jun 23, 2008 | 05:35 PM
  #96
ONDUHFLO's Avatar
Look up ^^
Dumb Turdpusher.
Old Jun 25, 2008 | 08:31 PM
  #97
87crexSi's Avatar
ok but what if there is no intake.....just straight filter on the turbo......and no slashcut in the downpipe??
Old Jul 18, 2008 | 04:14 PM
  #98
speedjunky01's Avatar
here is my setup
can
notice its baffled so it actually does something lol the key is to get it to reverse direction and slow down
the routing of the lines
notice the 90* angles in the intake it helps force air where its supposed to go and draw it out of the can
i think it would work great in both boost and vac, here is the reason for PROVIDING air to the valve cover and not drawing it out, in order to draw air out it has to come in somewhere so here is how PCV syhstem works stock, my system works like stock
Attached Thumbnails DIY Two Way PCV System How-To (HoMedepoT style)-catchcansetup.jpg   DIY Two Way PCV System How-To (HoMedepoT style)-occ.jpg   DIY Two Way PCV System How-To (HoMedepoT style)-stock_pcv.jpg
Old Aug 5, 2008 | 05:00 PM
  #99
fe3tcourier's Avatar
I've written an article on crank case ventilation here :
DIYEFI.org Forum - View topic - Crank Case Ventilation
Please be as critical as you can be (Trust HMT, sure can!), I'm interested to see the information and formatting etc be as good as possible. I hope it helps people in the future :-)
Fred.
Old Sep 20, 2008 | 08:21 PM
  #100
jacobgsx's Avatar
i took this pic and modified it to what i think would work for a slash cut tube in exhaust method...
