Turbo downpipe flange, where to find for td04 9b?
Old May 24, 2010 | 10:54 PM
hondaguy72's Avatar
Default Turbo downpipe flange, where to find for td04 9b?
I had bought a 14b/16g flange thinking it would be the same as it looks similar, but turns out the flange is quite a bit smaller. Any ideas on where I can find the correct flange. I've done quite a bit of searching. Turbo is from a 3000gt (one of the pair) for my 1st gen crx 1.5. The only thing I've found is from time to time a precat/O2 housing comes up for grabs on fleabay. Usually they go for about $50. The funny part is that OBX and others make precat delete pipes that use the exact flange I need. Any insiders get me one?
Old May 26, 2010 | 06:21 PM
Cyote's Avatar
Im planing on doing a similar setup on a buddies crx except its gonna be a twin 9b. but i can get you a good price on some front manifolds that have the flange on them and some o2 pipes but probaly not the flanges them self (they are rare to find). they would have to be cut off though. but thats fro 3si.org or local 3s group.
LMK if interested and i can give you some peoples emails and see if you can work something out with them
Old May 26, 2010 | 07:55 PM
hondaguy72's Avatar
That would be great. Let me know when.
Old Jun 26, 2010 | 08:34 AM
Cyote's Avatar
1OFF NEW 3S TD04 9B HEADER TURBO FLANGE REAR - Mitsubishi 3000GT / Dodge Stealth Parts
Old Jun 26, 2010 | 08:35 AM
Cyote's Avatar
Weirtech
Old Jun 26, 2010 | 08:36 AM
Cyote's Avatar
hey man LMK how this build turbos out im planning on doing the exact same build on the 1.5 l
Old Jun 26, 2010 | 12:25 PM
hondaguy72's Avatar
She's standing still at the moment while I search my *** off for this part. The link to the part in post #4 somehow isn't the right flange for the turbo outlet. The shape and bolt pattern is the same as a 14b, but the flange size is about 30% smaller. Here's the option I have on the table, but I'm too cheap to want to spring for this. It's actually a pair which would have to be re-welded anyhow.
That flange is possibly used for turbos with welded wastegates, which mine is not although I guess it could be. I'd rather use a stock wastegate actuator if possible.
Mitsubishi 91-93 3000GT GTO VR4 Turbo Pre-Cats Precat: eBay Motors (item 200486319124 end time Jul-01-10 14:275 PDT)
Old Jun 26, 2010 | 12:27 PM
hondaguy72's Avatar
Originally Posted by Cyote
Do the galant vr4 cars use a 9b? I'm thinking it's a 14b flange. I'll order it right away if it's the right one!!! I've sent an inquiry to Weirtech to confirm the fitment.
Old Jun 28, 2010 | 12:12 PM
hondaguy72's Avatar
Confirmed that this is the correct 9b flange, the Weirtech link. Cyote, you are awesome!
Old Jul 5, 2010 | 04:14 PM
Cyote's Avatar
well if its a galant vr4 turbo i have no clue but if its a 3000gt vr4 turbo then its a 9b and the bastards gonna spool if you even look at the petal lol but i guess thats good
what size injectors are you going with?? im thinkig of running the stock 3000gt vr4 360cc injectors but not sure if i want to get some bigger dsm ones or not. and the stock vr4 fuel pump lol . im planning on running the exact some setup as you. d15 with a 9b pushing 6psi (because 6psi is wastegate pressure). but the engine is about to die on me some im thinking a swap or something but ... idl yet lol + i just got a bigger turbo off a truck thats a little bigger then a 14b but im thinking of staying with a single 9b or twin 9b.... im thinking single 9b lol
what are your plans?? and specs and stuff??
pretty much im swapping all my leftover parts from my vr4 into my buddies crx lol
