how to tap into a d15b block for boost
Old Jan 1, 2010 | 11:51 AM
smurfed_CRX's Avatar
Post how to tap into a d15b block for boost
i have a d15b vtec that iam gunna go boost and i need to know how to tap the back of the block ive looked in this forum and cant find anything please help
Old Jan 1, 2010 | 02:17 PM
tecks's Avatar
its not that safe to tap it for an oil line all you need to do is get a filter relocator sandwitch which is like 30 bucks and tap the oil pan il tap your oil pan for free if you want i live in miami too.
Old Jan 1, 2010 | 06:20 PM
sounds good to me i would appriciate it i live around miami lakes and i will drive to where ever you are and iam gunna have to buy a that relocator thing
Old Feb 21, 2010 | 08:08 AM
Insidious408's Avatar
jus get like a blox oil sandwictch plate or be cheap and use a brass T fittin 1/8 NPT
Old Apr 5, 2010 | 10:26 AM
MAJORAHOLE's Avatar
lame-o, stealthmode oil adapter, ---- that sandwich bullshit.
it has outlets for your turbo, and gauge
Old Apr 5, 2010 | 10:45 AM
MAJORAHOLE's Avatar
acutally i think its tuner toys, and they are out of business. whoops
Old Jun 7, 2010 | 03:24 AM
FREAKBOY's Avatar
I used a T for the feed & relocated the filter to the front. Just make sure you have a restrictor in the feed to the turbo as they only need 10ish psi. Not much will kill a turbo quicker than feeding it 80 psi of oil!
Old Feb 25, 2011 | 01:25 PM
eg92si's Avatar
where would the oil restrictor go?
Old Feb 26, 2011 | 04:58 AM
FREAKBOY's Avatar
I put mine between the turbo and the feed, the difficult bit is actually measuring the pressure. I'm using guesswork but it's been ok up to now, 18 months on a cheapo eBay T3.
Old Feb 27, 2011 | 07:40 AM
93mr2guy's Avatar
------------- also sells the t and lines to run feed from your pressure sending unit. they also sell oil pressure restrictors.
