Honda GarageSale: LS swap, LSD trans, Turbo, FMIC, EF, MPFI, Etc etc
Old Jul 6, 2009 | 06:51 PM
The Milk Man's Avatar
Default Honda GarageSale: LS swap, LSD trans, Turbo, FMIC, EF, MPFI, Etc etc
Welp, I sold the white hatch shell and suspension, and this is all of what I have left. Getting out of Hondas for good, everything needs to go. I am firm on some stuff but everything is OBO. I prefer the items to be picked up, but can meet up to a reasonable distance if my schedule works out. Will ship, you pay shipping. All parts are located in Dahlonega, GA. Some parts are still dirty as I haven't had the chance to clean them.
-B18A1 Engine - $350 - #1370772, 170k bottom end. 15k on new top end - Replaced valve stem seals, valves lapped, timing belt, water pump, head gasket, cam seals, etc.
-LS Cable Transmission w/ LSD - $500 - Rebuilt, new 3rd & 4th gearset, new shift fork, OEM diff. bearings OBX LSD unit- rebuilt w/ upgraded bolts & washers.
-DSM 450 Injectors - $80 -
Obd1 Remanufactured Distributor - $60 - Advance Auto Parts lifetime warranty.
Chipped P28 Ecu - $100 - Purchased from Scotty @ Digitalboxtuning - OBD0 to OBD1 conversion harness too
Hasport B Series EF Mounts - $220
EF B Series Shift Linkage - $50 - Custom cut/welded
InlinePro Cast Turbo Manifold - $250 - B series, T3
Deltagate 38mm Wastegate - $75
JohhnyRaceCar FMIC- $200 - Good condition, just had FatCatFabrication weld on some new mounting tabs
AirResearch M10 T3 - $25 - Needs rebuilt, has shaft play
D16 Mpfi Intake Manifold - $30 - Comes with throttle body, tps
Si Mpfi Injectors - $30
Si obd0 Distributor - $40
Resister box - $10 - Have 2 of these
PM6 Si Ecu - $40
Camber Kit Front- $40 - Unknown brand, comes with DA A arms
EF Rear Strut Bar - $10 -
Turbo Timer -$20 - Swoosh
D15B Engine $50 - #3641858 Unknown mileage, turns over. PO replaced said it ran, but smoked. Rings??
HF exhaust manifold- $20 -
B18A Rebuilt Bottom End - $175 - Oem piston rings, ACL rod & main bearings w/ new thrust washers. All bearings platicgauged, and cyls. honed. New water pump, Comes with Feltpro topend gasket kit
B18A Head $25- Disassembled, everything's there though. Its under the other mess, lol
EF Headlights - $25
LS Halfshaft
OEM Honda wheels with caps - $40 - Set of 4
DA Hood - $25
EF Windows - $40
LS Valve Cover - $15 - Stripped
D Valve Cover - $10
LS axles - $40
Old Jul 6, 2009 | 09:30 PM
Oxide_Zer0yome's Avatar
turbo timer right hereeeeee
Old Jul 6, 2009 | 10:09 PM
You local or do you want me to ship?
Old Jul 6, 2009 | 10:56 PM
im in florida 34667 and is the shaft play in the m10 in and out or side to side??
Old Jul 7, 2009 | 08:57 AM
Rob91DA's Avatar
Interested in the Jumper Harness on the ECU and the Injectors, would you separate the harness from the ecu? If so, give me a price shipped to WA, 98023.
Old Jul 7, 2009 | 05:20 PM
Side to side
Old Jul 7, 2009 | 05:21 PM
Sorry harness is no longer available. Which injectors?? The DSMs??
Old Jul 7, 2009 | 10:25 PM
blackice90hb's Avatar
Damn cable trans, i need a hydro... bump
Old Jul 8, 2009 | 02:37 PM
k20ef's Avatar
HASPORT FTMFW!!!!!!!!!
Old Jul 9, 2009 | 08:54 PM
japhatch's Avatar
where are you located..interested in the tranny
