ihi rhb5 fitting size ?
Old Aug 2, 2007 | 05:34 AM
jdm 91 crx's Avatar
Default ihi rhb5 fitting size ?
what size fitting do i need for the oil feed line any one know oh and does it have to be flared ?
Old Aug 2, 2007 | 08:30 AM
bitchasscracker's Avatar
Default Re: ihi rhb5 fitting size ?
if its the same as a 14b you can just use the fitting from a honda fuel hook up. it looks to be the same size but i've never held one in my hand so i couldnt tell for sure
Old Aug 2, 2007 | 02:34 PM
E-b0la's Avatar
What is the turbo off of? Subaru RHB5's have a 10mmx1.5 bolt that uses a banjo. get the right sized banjo and use the existing bolt, or get a bolt if you don't have one at an autoparts store. A brake line banjo would work. Fords and other cars use 10mmx1.5 threaded banjo bolts a lot.
I'm not sure on the Probe RHB5's. I think the thunderbird RHB5 actually had an 1/8-NPT pipe thread for the oil inlet.
Evan
Fabrication
3
Dec 19, 2013 08:14 AM
Accord R33
Apr 11, 2005 11:58 PM
donalson
Apr 4, 2004 10:09 AM
Doofnoil
Mar 30, 2004 12:45 AM
scttydb411
Mar 17, 2003 11:12 PM
