Ls crank infused GSR
Old Aug 26, 2009 | 08:55 AM
BlackTeggy90's Avatar
Default Ls crank infused GSR
I've got a couple questions about this set up that I can't find answers to so if someone can help I would appreciate it alot and I already search and found some answers but not all.
I really want to know that since your using the ls crank and rods is there and need to do anything like notching the block? Also what bearings do you use the just the ls or gsr or maybe a mixture of both? And as far as torque specs for the bolts and everything is it still factory?
I plan and running a gsr block with ls crank, ls length eagle rods, wiseco 9:1 gsr pistons, and a b16 head maybe built. Any advice, experience or input would be greatly appreciated.
Thanks.
Old Aug 27, 2009 | 05:40 PM
40 psi 4g63's Avatar
i thought about and looked into the same thing but your better off doing a gsr block and crank or ls block/crank
Old Aug 28, 2009 | 07:25 PM
yeah it is real difficult to get info on this but its definatly been done and from what i hear its worth the effort, i found out some answers. but i would love if someone had some input on it cuz finding a GSR crank is redicously hard around me.
40 psi 4g63
May 5, 2010 10:30 PM
soontobeDA
Feb 9, 2009 12:09 AM
SQ is the SQUAD
May 16, 2008 10:11 PM
slammin86
Apr 27, 2004 09:39 PM
