ITR Mainshaft? need a new one questions and How to tell usdm from jdm?
Old Jun 6, 2009 | 12:30 AM
40 psi 4g63's Avatar
Default ITR Mainshaft? need a new one questions and How to tell usdm from jdm?
Mine is bad one of the teeth are gone. Can i use a gsr trans and just switch the lsd and be done or can i use the gsr mainshaft?
Do i need just the ls 5th gear and syncro to install it so i have a higher 5th?
I know its a lsd trans thats easy but how do i tell if its jdm or usdm?
It had j4d lsd stamped on it and it says s80 and some number after that on the case... How do i tell if the final drive? On both the case and lsd/internals? As before i bought it it was pulled apart?
pretty sure j4d is jdm only.
Just wanna make sure which fd it is and what parts i can use to fix it
Thanks for your help.
Acrite3404
Dec 3, 2007 08:37 PM
Poopadoop
Feb 26, 2007 09:59 AM
Inj3cted
5
Feb 26, 2006 01:50 PM
90turboteg
Aug 30, 2005 12:59 AM
jiujitsukid
Aug 17, 2004 04:37 PM
