need some help please
Old Jul 8, 2005 | 12:43 AM
chevy's Avatar
Default need some help please
well i dont even no were to start... well i got a b18c1 with a b16 head on it motor has 0 miles on it.... today i went over and but a stock b16 intake manifold on it and put on the timing belt... started right up.... but the idle was pretty high... so i turn it off check the codes... im getting 6,10,41... which i dont think those codes would make it idle high... so i though maybe the idle air control valve was hooked up wrong so i chage the plug... using a 96 gsr harness so i have a couple of left over plugs... i though maybe i hooked up the wrong one.. so i swap it and then the car idle's down but still has a little miss to it.. so im like ---- it.. so i then one of the fuel injectors starts to leak so i try to fix that.. but i couldnt stop the leak... but its a small one so i didnt think that would cause the car no to run.. so i take it down the block... and right off the bat i have no power... kind felt like it was out of time.. so i check that timing marks there right on... so i try to turn it back on with no luck... it turns over but it doesnt fire.. it trys to if u hold it to the floor.. but still nothing...
btw its running on a chipped p28 with a p72 map on it... its all i had... also the car will start if u push start it.... but still lacks power
racepak
Dec 18, 2006 02:56 PM
racepak
0
Dec 1, 2006 06:46 AM
91accordti
Jul 30, 2005 08:17 PM
1slowcx
0
Jun 18, 2005 01:22 AM
jman30513
Nov 13, 2004 07:35 AM
