Engine Management eCtune , Crome , AFC , FMU , Zdyne , Hondata , EMS , TE , Uberdata Anything to control your fuel, spark needs!
Weird AFR dips between shifts, ideas? OBD1/Crome
Old Apr 30, 2005 | 09:28 PM
FooK's Avatar
Default Weird AFR dips between shifts, ideas? OBD1/Crome
So my car has been running a perfect 11.8-12:1 AFR in WOT, never had any troubles.
Until last night at the drag strip
between each shift, when i got back onto the throttle, it would hesitate for a split second. Lucky for me I datalogged the passes.
For whatever reason, that hesitation is a dip in the AFR's to almost dead on 10:1 (sometimes 10.5 or 10.9:1) but I can tell its holding me back pretty badly.
Question 1: Could this be a symptom of a blown headgasket, I've been wondering if I've lost that cause I have a coolant leak and I cant find a dripping hose, just losing coolant and I can see it on the undercarriage. I plan on doing the ARP's and a new HG as soon as I can (money $$ )
Question 2: my clutch was slipping pretty bad too, could it be a side effect of that?
Car still idles normal, still pulls hard, doesnt smoke...
thoughts? comments? suggestions?
Old Apr 30, 2005 | 10:15 PM
Chris Harris's Avatar
Default Re: Weird AFR dips between shifts, ideas? OBD1/Crome
Sound like you need to work on your Throttle Tip-in when tuning.
Old May 1, 2005 | 03:53 AM
FooK's Avatar
sounds like spanish. i was watching it more tonite and it looks like it actually dips to 10.9:1, then as the rpms climb, the AFR's do too, a tenth of a point at a time, so maybe i just need to lean some ---- out. seems to be 4000-5000 rpm range, ill post the datalog in a few when i get on the laptop.
here it is
the datalog is attached, change the file extension from txt to zto and open in zeitronix datalogger software.
Old May 1, 2005 | 06:32 AM
SpankedYA!'s Avatar
Zeitronix datalog software http://www.zeitronix.com/images/disk1-V2.0.1.zip
Old May 1, 2005 | 03:50 PM
sohc_mshue's Avatar
sounds like you need to adjust tip in.
Old May 1, 2005 | 11:23 PM
FooK's Avatar
still sounds like spanish, guess i need to figure out what that is, and how to mess with it.
Old May 2, 2005 | 10:08 AM
projekteg's Avatar
what's your 'fuel modifiers' (if using uber), 'individual fuel multipliers' (if using crome) set at?
Old May 2, 2005 | 07:01 PM
FooK's Avatar
this is with crome, im looking for those settings, not sure where I'm supposed to be looking, but I guess if I look long enough I'l find it right?
Old May 2, 2005 | 08:57 PM
projekteg's Avatar
fuel tools (calculator icon in toolbar) -> advanced
Old May 2, 2005 | 09:51 PM
FooK's Avatar
there are for fields, main fuel, o2 correction, startup, tip in, all set to 1.000
really odd, i was looking at those earlier and they were greyed so i couldnt change them, opened it again to look at the names on the 4 fields, and they're no longer greyed, very odd. sadly im not gonna be able to do much about this now for a while cause i cant datalog, my laptop is buggin out on me again, i think it possibly fried memory again. poop.
TurboEF9 was talking to me in the beachhouse, doesnt seem to think its a tip-in issue.
