t3/t4 .57 trim and 38mm wastegate
Old Sep 2, 2010 | 05:35 PM
Hit Man's Avatar
Default t3/t4 .57 trim and 38mm wastegate
I have a jdm t3/t4 .57 trim turbo with a 20mm port on the exhaust housing for the wastegate. I have a 38mm dual port wastegate with a 6# spring. If I run my 6- stage boost controller, how much boost can I run before the 20mm hole becomes too restrictive and causes boost creep. I don't really want to port the housing if I don't have to beacuse I don't want to weaken the housing, but I can weld a pipe to the the header. This is on a hayabusa so room is limited and I'll only need 18-20 psi out of it.
t3/t4 .57 trim and 38mm wastegate-100_1147.jpg
t3/t4 .57 trim and 38mm wastegate-100_1148.jpg
t3/t4 .57 trim and 38mm wastegate-100_1139.jpg
t3/t4 .57 trim and 38mm wastegate-100_1143.jpg
t3/t4 .57 trim and 38mm wastegate-100_1149.jpg
Old Sep 3, 2010 | 11:39 AM
Clean's Avatar
the more boost you run, the less exhaust gas goes through the wastegate.
Old Sep 3, 2010 | 09:20 PM
Hit Man's Avatar
thanks, I was thinking bass ackwards.
soontobeDA
Apr 25, 2008 07:04 PM
2poor2tune
Mar 22, 2007 03:14 PM
hamburgler
May 7, 2006 04:39 AM
