Knife edge compressor wheel?
Old Mar 11, 2010 | 07:18 PM
akurtzer57's Avatar
Default Knife edge compressor wheel?
First of all I have a t28 that I upgraded the compressor and compressor wheel. Im thinking about knife edging the compressor wheel. I can't seem to find any info on doing it. Anyone here done it? Is it even worth the hassle?
Old Mar 12, 2010 | 08:37 AM
any modifications done to a turbo needs to be done by a professional. these things are spinning at 100,000 rpm and higher so any small change can effect the balance and destroy your turbo.
Old Mar 13, 2010 | 12:27 AM
hard2obtain's Avatar
i didn´t see the point of knife those edges if you got that nice turbo
Old Mar 13, 2010 | 01:02 PM
Snaglefast's Avatar
Angle grinder! And just take off the same amounts on each fin... If it looks good it should be balanced.
But really I don't think you'll benefit very much compared to the time and cost of balancing. But if you have access to a good quality lathe, PCD tooling and time to waste go for it.
Old Mar 13, 2010 | 03:10 PM
akurtzer57's Avatar
The turbo is going off to get rebalanced after I did the compressor wheel change.
Old Mar 13, 2010 | 03:15 PM
Snaglefast's Avatar
So you didn't try the whole "knife edging" bit? What turbo was it and what did you swap it with? Stock replacement?
Old Mar 15, 2010 | 10:09 PM
dot communist's Avatar
just... dont
/facepalm
Old Mar 16, 2010 | 12:29 AM
Ok, i think you got the answer you are looking for... most of people says leave those edges in peace XD
hoggy
Sep 28, 2005 02:33 PM
nsxxess
Jul 29, 2005 08:19 AM
dc2beatu
Jan 17, 2005 11:37 PM
pbwiz
Mar 31, 2003 07:20 PM
