oil feeds??
Old Apr 17, 2010 | 10:40 AM
1loynesy1's Avatar
Default oil feeds??
can i use a sandwich plate to feed the turbo with oil and return it back through the plate on a d15z6??
Old Apr 29, 2010 | 08:45 PM
eg8boosted's Avatar
just tap the pan by drilling it the place a fiting of any kind and JB WELD it
Old Jun 7, 2010 | 03:16 AM
FREAKBOY's Avatar
I tried to use a sandwich plate for mine but it was almost inpossible due to space and the shape of the block. Instead I took the feed from the oil pressure switch on the back of the block using a T off. I then used a mocal oil filter relocator kit to bring the the oil filter to the RH wing where the air filter used to be, this served well to feed my oil cooler too.
Drained oil from the turbo should always be fed into the sump via the shortest route with least resistance.
1loynesy1
3
Apr 29, 2010 08:42 PM
MikeJ-2009
Oct 10, 2007 10:07 AM
HMT-Admin
Aug 5, 2007 01:51 PM
