My mild steel manifold
Old Dec 6, 2009 | 07:43 PM
omgbossis21's Avatar
Default My mild steel manifold
This time the manifold build is just about done. In the pics its only tacked togother for fitment testing but i dropped it off today at my Dads house and hes going to weld it up this week so next weekend i should be putting it all togother. Hoping to get dyno tuned just after the new year..... Yes the manifold is made of mild steel and we cut the flange out of 1/2 mild steel (drill pressed holes).
This is all for my hyundai accent 1.5sohc thats built quite a bit, i've got an older post detailing info.
Old Dec 7, 2009 | 04:58 PM
Atreidies's Avatar
Nothing wrong with mild steel manis. You will want to clean up the runner to mani connections on the inside so they have a smoother transition, and make sure the flange is still flat after he gets done welding.
Old Dec 7, 2009 | 06:37 PM
yeah we will have to clean up those holes and clean up inside the large log when we cut it open for the collector flange. Should work nice those its just a small engine.
Old Jan 25, 2010 | 05:47 PM
Alright all my test fitment has begun! I have a little bit of grinding left to do on the manifold inlet pipes and at the collector but all in all its almost done. I got my wastegate modified (extended arm, modified bracket) and have my oil line ready to go (oil inlet). Everything fits pretty nice with the exception of the wastegate bumping the crank position sensor but its no big deal. Heres a few pics im going to try to get the rest of the grinding done tonight/tommorow night and have it started this weekend (hopefully).
[IMG]http://i50.photobucket.com/albums/f306/omgbossis21/01-24-10_1506.jpg
Old Jan 27, 2010 | 01:26 PM
sha-d's Avatar
wowzers!!!
goodluck with the mani!
Old Jan 27, 2010 | 03:32 PM
Thanks! Finished all my grinding last night so I'll start putting it back togother and add pics of the progress throughout the weekend. Lost my c-clip for the swingvalve so i gotta go get another one in the meantime.
Old Jan 27, 2010 | 07:06 PM
AaronZ34's Avatar
Looks good for a budget built HMT! But I'd be very weary of this, the crank position sensor is the only sensor on the engine that will cause the engine not to run/start if it's defective, and you don't want to be left stranded. Any other sensor you can deal with, limp mode is tuned in for that reason, but not the CPS. Otherwise, good luck!
Old Jan 28, 2010 | 06:44 AM
Yeah awhile back i had to replace the cps it just kills the car. Its the actuators housing thats hitting the harness plugged into it and I've got it wrapped in tape. The previouus setup i ran the turbo sat sooo close it i thought it would be a problem. The only problem i had was after a year or so i had to replace it lol Now I got a spare...
Old Jan 31, 2010 | 01:45 PM
hard2obtain's Avatar
Looks very original, just need to paint flat black when you finish it
Old Jan 31, 2010 | 04:59 PM
The flat black paint was already in the works when you posted lol Heres what I got done this weekend :
Not as much as i wanted to but the wastegate gave me more issues so i had to do some more fabricatin on it and i had to pull the radiator back out and mount the fan towards the other side to make room for the intake piping. I had another big project this weekend and that was installing some lights in the damn garage! I installed two 8ft double strip lights and used what used to be an outlet to install a double switch and ran all the wiring then patched the hole from it all. When i bought this house somebody had conveted the garage two a "two bedroom" with a bathroom ghetto style. I had to rip it all out so the garage has been in the works for awhile but its coming along. As soon as i can find my HMT stickers theirs one making its way under my hood =-)
